93 civic / obd1 jdm b16 swap..... 2 extra chassis harness plugs
I've got 2 plugs on the firewall that I have to figure out where they go.
One comes out on the passenger side and could either be plugged into the map sensor or tps sensor..... I don't want to cross them up.
The other comes out on the drivers side and will plug into the IACV sensor.
I believe newer civics have these integrated into the engine harness unfortunately mine does not. Any help would be very much appreciated since I am going to try to finish the wiring tonight.
Seagull Management
Re: 93 civic / obd1 jdm b16 swap..... 2 extra chassis harness plugs (racebucket_eg)
The fist plug goes to the map sensor, the other i'm not sure of, but if you post colors of the wires going into the plug i will find out.
Re: 93 civic / obd1 jdm b16 swap..... 2 extra chassis harness plugs (94EG8)
Thanks for the info, I will let you know about the other tonight.
Slacker93eg
09-12-2012 09:48 AM
sscivicsi
03-01-2010 08:10 PM
CRXified
35
12-29-2005 07:49 PM
