JDM B16 integra XSi Engine Swap to '91 CRX - Engine Mounts Help
we will buy JDM B16A integra XSi engine complete changeover swap kit for 1991 crx dohc zc.
But we dont know about the engine mounts.
stock jdm b16 mounts will fit to crx or not fit? what i have to do?
i found hasport mounts but i dont know need it or not? Stock xsi mounts are possibble?
We re 3 friends in here. and we will buy 2 B16 XSİ and 1 B16 EG SiR II engine...
'91 CRX D16A9 - XSi engine swap
'90 CRX D16A9 - XSi engine swap
'90 Civic Sedan D16A6 - 92-95 SiR II engine swap (LSD+Hydro tranny)
what is the differance between Cable transmission mounts and Hydro transmisson mounts?
and i searched aftermarket engine mounts. they re 3 pieces mounts.
Why 3 piece mounts? stock mounts are 4 pieces. Are we swap the engines with 3motor mounts??? or we use 3pieces aftermarket mounts + 1 stock mount? or just 3 pieces aftermarket mounts? im mixed.
3 mounts could be problem? how we stop vibration with 3 mounts?
and im thinking to buy rywire ecu conversion harness. but i dont know i have to buy or not...
thanks your helps...
Mr. Badwrench
Re: JDM B16 integra XSi Engine Swap to '91 CRX - Engine Mounts Help (CRX_SedanED4)
i dont know about the domestic chassis from where you are, so please forgive me.
BUT to put the dohc vtec engine in an ef chassis i nt he states, the chassis mounting tabs are different from that of the jdm counterpart. which leaves you 2 options. cut and move and weld the tabs on the car or get the hasport mount kit which locates them correctly.
hope that helps.
hope that helps.
TurboEM1
03-15-2006 04:58 PM
b16hatche
11-07-2005 03:43 PM
