Bah.. getting frustrated searching...
I have a 2000 Civic coupe(EJ8) w/ a B18C1. I'm Looking for a solid converter or test pipe I can buy somewhere that will bolt up between a DC sports B18B1 header (GSR header was too short), and an OEM Civic EX exhaust. It has an OEM Civic converter in it now, but the guy I bought it off of had to cut the front flange and rotate it to make it bolt up to the header. Needless to say it's not a very good weld job and too rusted to cut and re-weld... I've tried an LS converter and it comes up about two inches shy. I thought maybe the SI converter would work since it's a B-series motor.. and that appears to be the same converter as the EX anyways. Just wondering what you guys with B-series swaps in 99-00 Civic coupes use to complete your exhausts... Please help me out if you can, need to fix this ASAP. Thanks^^
