Mounts don't line up?
i have a 90 CRX Si with a ys1 trans on a b20.... long story short i have innovative mounts.. i got the trans mount on and the back lined up yet the driverside mount is angled back and it doesnt seem as though it will fit at that angle and im having trouble getting the bolt through... any advice, pics or anything?
1 Post
Re: Mounts don't line up? (Blue-EM1)
You may have to loosen the other mounts if you have them bolted tight already...it seems the easiest way to get the drivers side mount in is to put the bolt threw the mount and then try and bolt the posts on the block mount up into it...HTH
10
03-05-2003 10:29 PM
