H2B help needed!!!!
Old Jul 28, 2008 | 09:03 AM
SL0-hatch's Avatar
Default H2B help needed!!!!
okay. well i've got a GSR ek hatch right now. And I just picked up an H22A4. I'm planning on doing an H2b build with the QSD kit.
1. My question is does it matter if the motor came from and automatic prelude or 5-speed prelude?
2. Do I need to change anything from the automatic longblock to 5-speed? Also, what would I have to do to the wire harness that I already have, other than extending the alternator bracket?
3. What actually needs to be done to the crank pulley for this particular kit?
4. What fuel rail do I need and do I need an aftermarket fpr?
5. Could I use the stock intake manifold?
I've been searching here on h-t but I haven't quite found the answer I've been looking for. Sorry if this thread is just redone dent.
Also, any other help/advise would help! Thanks ahead of time!
Modified by SL0-hatch at 10:20 AM 7/28/2008
Modified by SL0-hatch at 1:14 PM 7/28/2008
Old Jul 28, 2008 | 10:57 AM
2fastGSR's Avatar
King of the One Liners
Default Re: H2B help needed!!!! (SL0-hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL0-hatch &raquo;</TD></TR><TR><TD CLASS="quote">1. My question is does it matter if the motor came from and automatic prelude or 5-speed prelude?
Open up wide here comes the spoon feeding train . . .
1. No it does not matter. It has been debated if the auto/ manual h22 are the same. Some have said that cams are different but there has been NO proof to justify this. My motor was an auto and it was a pretty strong motor.
2. The only thing you would need is manual pressure plate bolts ( auto is shorter) but since you are going with QSD kit then that is already covered.
3. The power steering part of the pulley needs to be shaved off. or get an f20 crank pulley.
4. I would just get an aftermarket fuel rail so you can move the fuel inlet to either side. But you could also go with a 90-93 accord fuel rail and that will work. You dont NEED an aftermarket FPR , but isnt a bad thing to buy if you plan on future modifications
Old Jul 28, 2008 | 11:42 AM
SL0-hatch's Avatar
Default Re: H2B help needed!!!! (2fastGSR)
thanks for the help!
Old Jul 28, 2008 | 12:13 PM
SL0-hatch's Avatar
also, could i use the stock intake manifold?
Old Jul 28, 2008 | 12:43 PM
2fastGSR's Avatar
why would you not be able to ?
Just need to have the iabs removed or have an ecu capable of opening/closing them. . .
Old Jul 28, 2008 | 12:53 PM
turbohybridlude's Avatar
yes u can use the stock intake manifold
Old Jul 28, 2008 | 01:19 PM
SL0-hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">why would you not be able to ?
Just need to have the iabs removed or have an ecu capable of opening/closing them. . . </TD></TR></TABLE>
thanks for the info!
Old Jul 30, 2008 | 06:45 AM
SL0-hatch's Avatar
well yesterday i put the motor on an engine stand and come to find out its got a little crack in the block.
here's some picture:
I was just wondering if any of you would think that this crack would effect the motor at all?
also what am i suppose to take off in the picture below, i know the balance shaft but which one is that, and how do i take it off? or could i just leave the balance shafts on and take the belt off. remember i'm using the QSD kit!
Modified by SL0-hatch at 8:10 AM 7/30/2008
Old Jul 30, 2008 | 10:15 PM
YeeJ6's Avatar
I've been searching here on h-t but I haven't quite found the answer I've been looking for. Sorry if this thread is just redone dent. </TD></TR></TABLE>
LOL!! thas funny... anywho, all the answers to those questions can be found in the h2b faq thread and h2b discussion thread
TylerC161
Nov 25, 2007 10:08 PM
gabrielle
Jun 27, 2006 09:54 PM
MAX HARDCORE
Sep 1, 2003 06:50 AM
