itr swap got a problem when the car is warm or the weather hot
i dot jdm itr swap and never had this problem untill it got hot outside ....when the car gets warm the car runs at like 1800 rpm and eats gas like crazy and backfires at 4000 woun't let it go over the 4000 (what have been done brought to four shops it throws the tps cheak engine but tps changed ,idle control valve changed, distributor changed, sparp plugs and wires changed ,oil pressure selinoid changed.. can't figure it out please help (sorry for spelling)
obviously untuned?
there are temp tables in the ECU that run the car differently when it's warmer out. That may be your problem.
the TPS code may be the sign of faulty wiring, faulty grounds or the TPS being out of adjustment.
all of which would cause this problem.
streetmodified
08-03-2006 08:29 PM
