obd2 distributor pinout?
just search theres one somewhere on here. if you wanna convert it to obd1, just look at the plug they go in the same way, just unpin the icm pin first and put it under the blank spot, then go for there in the same order in the same spot. as for the 2 big plugs, just plug them in 1 way, if your rpm doesnt work then switch them around.
efdrifter
11-08-2007 09:14 AM
SuicideSlide
14
05-16-2005 12:10 PM
0bd2, acura, b18c1, connector, distributer, distributor, distrubor, disturbutor, honda, obd2, obd2a, odb2, pin, pinout, plug
