GSR compression???
Old Jun 28, 2008 | 12:41 AM
kasperxtcy's Avatar
Default GSR compression???
sup guys i have a little problem. i just rebuilt my gsr head because one of the valves cracked on me. after placing everything back to where it is supposed to be i did a compression check. i got 150psi all around except on #3 120psi. i know it is low but could it be that my timing is off and that is why i am getting low compression. the reason why i am asking this is because the first time i did a compression check on the motor i got like around 240psi and like 180psi on #3. (before the valve cracked on me)
any input will help the motors running like its got no power right now.
Old Jun 29, 2008 | 08:28 PM
mnskateboarder's Avatar
Default Re: GSR compression??? (kasperxtcy)
yeah your compression definatley is not right, it should not be down near 150 at all.
Old Jul 2, 2008 | 06:22 PM
kasperxtcy's Avatar
Default Re: GSR compression??? (mnskateboarder)
anyone else???
Old Jul 2, 2008 | 11:35 PM
kasperxtcy's Avatar
bump
Old Jul 5, 2008 | 08:23 PM
JDM_Honda_349's Avatar
was there anything changed when you did the valve job? Did you do the work or did someone else do it?
Old Jul 7, 2008 | 03:30 AM
b20vcrxsir's Avatar
Default Re: (JDM_Honda_349)
Sometimes when you take a head in for valve work they mess with the valve lashes, so u should check your timing and make sure the valve lashes are adjusted within spec.
intake - 0.006 to 0.007- inch
exhaust - 0.007 to 0.008 - inch
good luck
kasperxtcy
12
Jul 4, 2008 10:24 AM
acman1
May 21, 2007 12:06 PM
Layziejoe775
Aug 26, 2006 03:54 PM
mugenwannabe
May 11, 2005 08:14 AM
