Help! Accord motor civic body/harness no acceleration
EGsedan and harness, d15 dizzy with F22b2 non vtec ran like a dream, now it won't make it above about 2500-3000 rpm without acting like it's bouncing off a rev limiter slowly, in gear and out..ICM maybe? Checked the ignition timing rotating the dizzy and it about fell on its face
A little confused :/
Re: Help! Accord motor civic body/harness no acceleration
it's definitely throwing the cel, the egr isn't wired..haven't moved or unplugged any sensors, the barometric pressure sensor came unplugged but I don't imagine that's the cause.
Can't use the f series dizzy, the swaps wired with the eg harness so no plug for the coil..she ran perfectly before but today I left hard on it and it "like" died, it idles smooth (a little lower than before) but the second I try to rev up or run any gear further than like 2500 rpms it starts stumbling like a low set rev limiter..
Remove the distributor and check to see if it leaking oil into it. If so change the dizzy seal and give it a new full set of plugs cap rotor and wires.
Check that cel!
Plug any sensors that came part back in.
Check that cel!
Mr.ITP
04-08-2013 08:21 PM
Juan_Mitosis
01-28-2008 05:12 PM
zeroracerh
03-13-2004 04:40 PM
