1997 Civic EX - B18c swap questions
Old 04-17-2013, 06:07 PM
Jackie Wallace's Avatar
Default 1997 Civic EX - B18c swap questions
I have a 1997 Civic EX w/ a B18c swap.. Here's my question
- Which AC System do I need? From an Integra or for 97 Civic?
- Which Engine Harness SHOULD I be running? I have an Acura Harness right now that came w/ the swap but it's causing some issues w/ ECU
I was told to put the 97 Civic EX 5spd w/ VTEC Harness back in and splice what I need off of the Acura harness just wanted to ask before moving forward.
Old 04-18-2013, 04:17 AM
Echelon's Avatar
Default Re: 1997 Civic EX - B18c swap questions
You can either use a 99-00 Si harness or use your stock harness and splice the wires that you need. The Integra hardness won't work because it's a 2 piece harness so don't even bother using it.
AC system you can use your stock AC lines and compressor with del sol vtec bracket.
https://honda-tech.com/forums/showth...ghlight=series
Reason no one probably answered is these are easily googled questions and you could have searched.
Old 04-18-2013, 05:55 AM
kyden's Avatar
^^ he cannot use a 99-00 si harness
you reuse your stock harness. almost all of it will plug in. you will need to rewire the IAT plug, plus add iab wire if you're using it.
Old 04-18-2013, 06:04 AM
supremeXorio's Avatar
Have a 98 cx hatch planning to do same n have the ex harness
Old 04-21-2013, 04:34 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
thirsk66
08-30-2015 09:49 PM
Gabe624
06-09-2013 08:58 PM
oosykooo
12
02-06-2012 03:03 PM
integrasi22
03-21-2011 08:56 PM
blkrice
10-02-2002 04:13 PM
Quick Reply: 1997 Civic EX - B18c swap questions
