B20vtec-turbo with B16 head...what compression ratio?
Don't tell me what supporting mods I need...this is a very simple question. I'm building a B20vtec turbo using a B16 head and aiming for 450-500whp. What compression ratio pistons should I use? and should I use flat faced valves? I was thinking 9.7:1 pistons with flat faced valves, but I wasnt sure if the CR would be too high. Tell me what you think I should run and why...
Re: B20vtec-turbo with B16 head...what compression ratio?
If you are using a B20B block with stock pistons with an un milled B16 head 9.16:1, if using a B20Z with stock pistons 10.4:1. Both good for boost but the B20 has thin sleeves that like to crack past 350whp. If you plant to go to 450-500whp then you need to do pistons and rods and sleeves or go with a B18 block that has thicker and more reliable stock sleeves but with your goal you would be pushing the limits of B18 sleeves as well. I would go with about a 10:1 compression.
Personally i like higher comp when turbo 10.5-11.5:1. Deff want to rethink that b20 bottom for that hp. Unless your sleeved then have a ball. Comp ratio does not matter as u tune it with proper gas and all other normal stuff
again...dont tell me about supporting mods...my block is sleeved amongst other things....the question is:
what compression ratio should i run?
sleeves are not thinner, they are weaker. the calinera are ctually thicker than B18.
personally i like high compression motors. even better if you can run e85.
Iam pretty sure i did *** hat. And the thing is you did not specify enough info on your setup, i and the others were only telling you the common issues with turboing a b20. Secondly why not do some research for YOURSELF and pick a comp ratio. Lastly why not talk to your tuner and what he is comforable tuning.
How is having a properly built motor a supporting mod? It is not it is a correct setup. Pick a compression ratio that you are happy with. 10:1 at the least is what I prefer, higher compression makes for a more responsive motor on and off boost. Dont be such a dick, you gave next to no info on your setup and goals so you got generic answers.
B20 sleeves while different than all other B series sleeves are still thinner. Bored to 84mm instead of 81mm. B20 sleeves are a well known weak point in that motor. I have seen 300whp well tuned B20's crack sleeves at the top.
1 Post
Ive seen a stock sleeve 84.5mm b20vtec with a ge block guard make 696whp and a stock sleeve, piston, rod, no block guard b20vtec make 450whp, both tuned by the same guy. You guys need to sit a b20 block and a b18 block next to each other and look at the difference in the sleeve material and you will realize you can make more power than you think with a stock sleeve b20. To answer the op's question, go with cp 9.7:1 pistons and ferrea valves, if you use flat face it still wont be too much compression as long as you use good fuel and a good tuner. So your good either way.
^^^ pushing the limits of the block big time. I bet in a year or so those motors wont be alive anymore. I call BS on 450whp on a stock B20 bottom end, if the sleeves dont fail either the rods or rod bolts will under that much power. Maybe just a dyno queen but no way a stock B20 could live long at 450whp.
1 Post
i would suggest asking whoever is going to be tuning your car these questions.
so you have both a B20 and another B-series side by side? cuz i have. and the distance between the coolant jacket and the pistons is greater on a B20B than a B18C.
2019 still plenty of b20's haha
Haha, interesting how old threads get brought back up...I figured since I'm bored and this came back up, I thought I'd share what I did at least. I went with 8.5:1 JE Pistons, Crower Rods in my sleeved B20Z block mated with a built B16 head and a T60-1 way back in the day. It was good for 627whp @ 38psi (high boost) and 442whp @ 22psi (low boost).
nitrousjunkieCRX
07-16-2004 12:42 PM
