1995 Integra LS to B18C5 Type R JDM swap help
What is the easiest way to convert the rhd harness to work in this car? Anything else i should know before diving in? Thanks in advance
Re: 1995 Integra LS to B18C5 Type R JDM swap help
a rhd harness is totally backwards. You would have to tear the entire thing aparts and re-run it. which prolly wouldn't work and isn't worth the time. Just wire in v-tec of get a harness form a gsr or type r.
And a B18c5 is not a JDM type r, it's a USDM.
Thanks guys i ended up figuring it out. Only took a couple hours and we modified the original engine harness and installed it on the new engine and bought an ECU jumper.
