GSR into EM1 NOOB. HELP!
hello, as the title states, this is a noobie question. First off, im looking to purchase this EM1 with a gsr wap tomorrow. I was wondering how I can tell if it is an OBD1 or OBD2? also, to replace the motor mounts, i read that i would need the GSR driver side mount while being able to use the other 4 stock em1 mounts. someone please get back to me asap!
Re: GSR into EM1 NOOB. HELP!
http://www.preludepower.com/forums/s...d.php?t=314625
This might help u same goes for b18 b16 motors
Thanks! Now the only thing I need help with is the motor mounts. I don't want to go with the innovative or hasport mounts. I like the feel of OEM since I'm going to be dailying the car for a while. If anyone can help me with that it would be much appreciated.
If you swap the driver's side GSR engine bracket ("3 bolt type") with one from a '99-00 Civic Si (DOHC 1.6L VTEC), which is a "2 bolt" type, you can use the stock driver's side mount and "S" bracket.
yo JRCivic1, so youre saying, by using the GSR bracket, i can use the stock engine mounts?
