00 Civic/GSR swap - Help Understanding CELs after leaving dealership
Old 02-27-2013, 08:28 AM
JPerkMr954's Avatar
Default 00 Civic/GSR swap - Help Understanding CELs after leaving dealership
After leaving the dealer this morning, I had them give me a list of my CELs so I can go ahead and address them before going forward with my project.
Before you guys start saying search the thread, I have done that and I have information about the codes, but I don't really understand it.
The code specifically I am looking for information about is P1337. I see it says " Crankshaft Speed Fluxuation Sensor - CKF Sensor - CKF Sensor Circuit - ECM/PCM.
Now I know that this is related to the crank, but I need more information. Also, I cant find the part number for this " sensor " if this is what is needed to fix it.
The other is P1259 which is VTec Solenoid Valve/VTec Pressure Switch. Im looking for the part number for the Solenoid now, I don't know if the pressure switch is all in the same thing or not.
Old 02-27-2013, 08:31 AM
B_Swapped93's Avatar
Default Re: Help Understanding CELs after leaving dealership
Take it back to the dealership ! get them to do there job unless you just wanted them to tell you the codes ?. would help to know the car/engine
Old 02-27-2013, 08:35 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Can you give us some information on the car and the engine, the ECU? etc
Old 02-27-2013, 12:42 PM
canadaek's Avatar
those two sensors are not on jdm motors so if it has been swapped you won't have them . you can add the vtec oil pressure switch it goes on the vtec solenoid housing and there is a wiring trick for the crank flux sensor. (it's mounted on the oil pump housing behind the crank pulley) http://www.ff-squad.com/technet/ckftrick.htm
Old 02-27-2013, 01:24 PM
JPerkMr954's Avatar
Sorry guys...
the car is a 2000 honda civic ex. The motor is a GSR Head.... and a B16A2 block...
Old 02-27-2013, 01:48 PM
Former User's Avatar
What ECU? Look behind the passenger side kick panel.
Old 02-27-2013, 01:55 PM
canadaek's Avatar
Default Re: 00 Civic/GSR swap - Help Understanding CELs after leaving dealership
well if it's an a2 block it should have a crank flux sensor . a2 = 99-00 em1 SI/SIr
Old 02-27-2013, 05:16 PM
JPerkMr954's Avatar
P2T 99-00 SI ecu...
Old 02-27-2013, 07:32 PM
doctorake's Avatar
Are you sure it is a b16a2 or is it a b16a swap?
Old 02-27-2013, 08:03 PM
JPerkMr954's Avatar
B16a2 with a GSR head....
Old 03-06-2013, 04:12 AM
JPerkMr954's Avatar
I'm going to replace the Vtec solenoid and pressure switch to take care of one issue... I was told that going to an OBD1 chipped ecu will eliminate some of the other codes in which I was throwing, ( O2 senors, Crank possibly and Idle )
Old 03-06-2013, 06:27 AM
kyden's Avatar
a crank fluctuation sensor code (ckf) has nothing to do with your driveability.
which o2 sensor code are you throwing?
Old 03-06-2013, 07:58 AM
Technical Hero
HondaPartsHero's Avatar
See if you even have those sensors
CKF
Pressure switch
Old 03-06-2013, 08:04 AM
JPerkMr954's Avatar
The codes I was given are as follows:
P0505
P1259
P0135
P1337
P0141
Old 03-29-2013, 07:27 AM
JPerkMr954's Avatar
Update:
I took my car to the shop, and they pulled the codes again, and then erased them all to see which were hard codes. The Vtec related code did not return, only the O2 sensors 1 and 2, and the crank position sensor related codes. He checked my vtec pressure switch and it worked he said, but when I drive the car I still can not hear vtec engage. I'm starting to just assume that this is due to the cams that I have, and its just not the type of crossover that I want. There really cant seem to be any other issue... unless there is an internal issue inside my head itself ( just a random guess )
E JAY 1
03-18-2008 06:01 PM
88hatchef
02-22-2006 12:59 PM
voltageGSR
12-07-2003 10:28 AM
2000CX
12
05-17-2003 10:19 AM
memphiss13
01-19-2002 04:15 PM
Quick Reply: 00 Civic/GSR swap - Help Understanding CELs after leaving dealership
