white smoke from a new jdm d16 vtec?
Lately I notice that is a white smoke or gray color coming out from the muffler? Even wen I drive. Or just iddling. This is a new jdm motor and for some reason the fan is on all the time. Can someone tell me if there is a problem. !! Thanks.
Re: white smoke from a new jdm d16 vtec?
Oil still the same level. And it doesn't smell sweet. LoL but maybe I should do a compression test. Thanks.
very well could also be a leaking inj. i have had this problem in the past. full built a bottom end (20+hrs spec'ing out bearings, measureing so on) put all together and bam instant white smoke. turn out i put on a fuel pressure tester and kick'd fuel pump on and off and pressure bled off in matter of seconds. but when it ran it looked just like a headgasket/burning coolant.
