h2b clutch opinions
h2b clutch opinions
In the next month or so I'll be ordering all the parts for a h2b in my ej6. I currently have a b16b and will be using that trans with a h23. My question is what would be a good clutch to use. In my car now is a exedy stage 1 with about 5,000 miles on it and even though its relatively new I'd rather be safe then sorry and out in a better clutch that way I don't have to change it out 6 months down the line unless you guys think that clutch will hold up. If it makes a difference ill be using the qsd kit and the motor will be all stock with bolt ons
Re: h2b clutch opinions
u should be fine with the stage 1 but i got a cc clutch kit 6 puk sprung in mine just pulled the whole build apart and clutch is still good and ive had the swap together for about a year
Thanks man. I've been shopping around and have been looking into 6 puck clutches so might go that route
Im using a stock b series clutch with the H23V motor. When I did the swap, I bought a new clutch disc, but kept the original B16 pressure plate (230,000 km on this piece). This setup works great, doesnt slip at all.
