B20b swap
Old Feb 11, 2013 | 05:21 PM
Xcisions's Avatar
Default B20b swap
Okay so ive been doing some reading and so many people do different things with the swap. Different transmission choices, ecu, mounts, etc. The problem im running into is which is right. hmotorsonline has 3 choices for the b20b they each have different compressions and hp. So that's another question. Would the parts required to do the swap, would they remain the same? I know about searching and googling, but like i said different people suggest different things. Any kind of help would be great!
Old Feb 12, 2013 | 10:26 AM
Xcisions's Avatar
Default Re: B20b swap
To add this is going in a 99 civic ex. I would really appreciate any kind of help because ill be doing this soon.
Old Feb 12, 2013 | 12:15 PM
kyden's Avatar
the parts required are all the same.
Old Feb 12, 2013 | 02:51 PM
Xcisions's Avatar
So,
1.B Series Mounts - The 00-99 si mount does that have to be welded in?
2.B Series Shift linkage
3.B series Axels
4.B Series Hydro Trans - LS, SI, Type R
5.Harness - Which harness? The one that comes with the b20b or from my car?
6.Ecu - Same question as number 5
Old Feb 17, 2013 | 11:48 AM
94EG8's Avatar
Seagull Management
No.
Needs to come from a '94 - '01 Integra or '99 - '00 Civic Si (or JDM '92 - '00 Civic with B-series)
Either reuse the harness you have and modify it to fit (requires lengthening a few connectors), or you can use a '99 - '01 USDM 5 speed CR-V harness as it is a direct plug-in in a '99 - '00 Civic. Also a '99 - '01 USDM CR-V distributor will have the correct small plug for a '99 - '00 Civic eliminating the need for cutting and splicing/repining/adapter harnesses/hybrid distributor.
You can actually use a '98 - '01 USDM CR-V ECU, or you can use an '00 - '01 Integra LS ECU with the immobilizer removed (H-T user Katman used to, and as far as I know still does immobilizer removal) The CR-V ECU doesn't have an immobilizer.
Old Feb 18, 2013 | 12:57 PM
blackeg's Avatar
if using an oem ls ecu, i recommend using and adjustable fpr and bumping the pressure up a bit. my b20b with ls ecu ran lean at cold start and wide open until i added the fpr and cranked up the pressure into the 50's psi range.
the o2 sensor does the job in the rest of the fuel map keeping it within spec
Old Feb 19, 2013 | 11:42 AM
CRISTON's Avatar
I am currently running a B20 swap in a 98 ex. In adding a fuel regulator would i have to change the rail or would the stock rail be ok?
Old Feb 19, 2013 | 06:25 PM
hybridmiklo's Avatar
did you create this thread? Go make your own
soodominican
Honda Fit
11
Sep 8, 2010 10:43 AM
95Sol99civic
Dec 11, 2009 05:50 PM
jdmdelsolsi
Jun 1, 2006 11:56 PM
JesseNofi
Jan 29, 2004 09:12 AM
