h22a swap no longer starting
Old 05-14-2013, 11:49 AM
koalayummies's Avatar
Default h22a swap no longer starting
Two days ago the car started dropping rpm fast and would just buck me when I tried to accelerate then it shut off. When she shut off the relay box (under my dash) started ticking extremely fast. I coasted it to my grandfathers house. The fuel pump primes. It doesn't sound loud at all tho a very quiet hum you practically have to put your ear to the pump to hear it. Pulled the plugs they were black as night. Changed the plugs as well as the cap and wires, still nothing. Sea foamed the gas tank the car ran for like 3 hours maybe at night when it was around 35 degrees then this morning she started up went literally a block then fell on its face. Same as before the revs went sporadic and then the engine died and the relay ticking started.
Confused as ***** any ideas?
Old 05-14-2013, 01:15 PM
n*werk's Avatar
Default Re: h22a swap no longer starting
Do the basic, check fuel, timing and spark. Then go from there.
Old 05-14-2013, 08:34 PM
ej7attack's Avatar
pull the relay (main relay) and check all the solder joints really good. resolder if you find one or two with a crack.
Old 05-15-2013, 08:38 PM
Thanks for replying, It turned out to be the ground for the ecu under the thermostat housing. Thanks!
Old 07-26-2013, 08:25 AM
csb16b's Avatar
my fuel pump primes sporadically
Championship
11-25-2010 05:36 PM
DOHC_ZC
02-16-2010 06:25 AM
alscrx
03-05-2009 03:07 PM
wowverycool
05-17-2006 06:20 PM
jondancer
04-13-2004 03:50 AM
Quick Reply: h22a swap no longer starting
