B18b1 With Skunk 2 Manifold?
i have a b18a1 with a skunk 2 manifold in my 98 Lx..i wanna kno where did u guys hook up ur EVAP solenoid hose and the pcv valve hose...if i connect my pvc hose to the manifold then i have no place to hook up my evap solenoid hose and vise versa.....any ideas
In this pic i have the evap solenoid hose hooked up to the mani and the pcv valve un plugged
Re: B18a1 With Skunk 2 Manifold?
That hose that u see coming out from the center hole in the pic is the one i have hooked up to the evap solenoid ....but right now the evap hose is unpluged and the pvc is plugged to the center hole....idk where i need to plug in the evap hose
http://www.acuraautomotiveparts.org/...ll&systemcomp= this site has great diagrams just enter the year of the engine and the trim lvl would be LS
the hoses that go to the evap solinoid connect to the a plug on the TB and one on the back of ITM it's really small. the pcv is supposed to be in the center correct that first it's more impostant then the evap. have you looked at a vac hose diagram for an integra ls ?
See on the pic below its circled ..I have that evap Not the small one
edit: did some searching for you,http://www.team-integra.net/forum/14...m-install.html
don't know if it's rellavant
Enta
01-29-2007 03:51 AM
Nextelbuddy
03-26-2004 05:08 PM
citanest
01-14-2002 10:26 PM
