New kind of G23 - do you think it will work?
Old 02-12-2013, 06:53 AM
honda_12V's Avatar
Default New kind of G23 - do you think it will work?
Hey all,
I have been eating every one (pirate / AFA accord / Rosoko) mind for some time now about g23 etc.
My reading brings me to this spec:
H22a block - darton replacement sleves - 89mm bore
K20 pistons - C/D - 30 - pin is same 22" and no issues with FRM due to sleves
F23 race eng rods - again pin is 22" (same as h22 and f23)
F23 crank - 97 stroke - 55mm mains on a h22 block 1998+
Acl bearings
ARP bolts
Head:
Crower stage 3 cams ( i know not the best)
Super tech valvetrain
Port match - mild port work
header
BMC Street manifold
70mm TB
Now compression and numbers.
Using CP flat tops - 11.42:1 ( almost perfect for daily driver running 87-89ron)
Gasket - OEM 3 layer (0.026)
Displacement: 2413cc
Rod to stroke ration: 1.45:1 -
Mean piston speed: 2147fps
Piston to deck: 0.00
My GOALS:
Stroker motor
RELIABLE
Make power 275-300hp
SO WHAT YOU THINK - such a mix would work? Is my research solid?
Please discuss this
Kind Regards
Old 02-12-2013, 07:18 AM
honda_12V's Avatar
Default Re: New kind of G23 - do you think it will work?
And yes we could use a f23 block - but my idea is to stroke the h22.
Trying to do a good job with least possible funds.
Please give opinions.
Old 02-12-2013, 04:20 PM
RogueSteel's Avatar
This would be a very interesting setup, I would love to run an N/A G23, looking to start building one myself! I'll defiantly be keeping an eye on this tread! While I may be of no real assistance other than cheering you on, I would love to see this build running how you want it to! Good luck!
Old 02-12-2013, 06:56 PM
honda_12V's Avatar
Thanks man the motovation does help.
Can anyone confirm interchange of these parts please.
Regards
Old 02-24-2013, 09:32 AM
Greg Robinette's Avatar
Originally Posted by honda_12V
Hey all,
Acl bearings
ARP bolts
Head:
header
BMC Street manifold
70mm TB
My GOALS:
Stroker motor
RELIABLE
Please discuss this
Kind Regards
I was going to do almost the same thing a few years ago. I had an H22 block sitting around, F23 crank, but using an H23 nonvtec head.
honda_12V
02-13-2013 09:55 AM
97_Built
12-10-2009 11:13 PM
michaelprice83
02-16-2009 09:27 AM
nemisish20
11-10-2008 07:21 AM
Fly1865
02-07-2004 09:55 PM
Quick Reply: New kind of G23 - do you think it will work?
