b20V swapped CRV wont fire up
just swapped my b20vtec in my 00 crv and its not firing up.
things i've tried:
changed dizzys
new plugs
checked mechanical timing
different basemaps
cleaned grounds
motor is:
b20 bottom
gsr head
itr cams
b16 dizzy
00 SI engine harness
blox intake
holley 70mm tb
rc310cc injectors
motor spins super smooth, its getting fuel i smell the gas, backfires every once in a while(into both intake and exhaust), just wont fire up. plugs arent fouled, plug wires are on dizzy in 1342 pattern, 45psi fuel pressure.
s300 in a p28.
any other info needed just ask. this is my DD so i need it fixed asap. all parts are brand new except block, head, cams.
things i've tried:
changed dizzys
new plugs
different basemaps
cleaned grounds
motor is:
b20 bottom
gsr head
itr cams
b16 dizzy
blox intake
holley 70mm tb
rc310cc injectors
s300 in a p28.
Re: b20V swapped CRV wont fire up
got a new dizzy today and it fired right up but it sounds like a diesel
i did valve lash adjustment, set dizzy timing and made sure firing order is correct and it still sounds odd.
What does your compression test tell you? Sounds dumb but do you have all your spark plug wires in the right spot on the dizzy? Sounds like it could use some tuning.
evil em1
23
06-21-2006 04:35 PM
XJamesX
13
05-29-2006 10:10 PM
Hockey27925
07-18-2005 07:17 PM
sodacan33
12
06-22-2004 08:47 PM
