h22a with h23 crank
h22a with h23 crank
hi there ppl im wirting you all the way from germany cause i cant seem to find any more information on my project which i mentioned above as my topic.
i´ve read so much about this topic in so many different forums and nowhere do i seem to find an anwser to my question so i decided to ask you direktly
my aim
h22a2 block
h23 finebalanced crank
h23 rod´s
lighweight flywheel
h22a2 pistons
H22 Balance Shaft Eliminator
my question is will the crank of the h23 last the rpm of past 7k after fine balancing
and is it reliable as a weekend car (civic Ej2).
im not a racer type guy but every also often i do want to push the engine
im open for every remark and comment
many regards
my aim
h22a2 block
h23 rod´s
lighweight flywheel
h22a2 pistons
many regards
Re: h22a with h23 crank
Some Accords in Japan have something called the H23A dohc vtec. It's a factory H23 with an H22 vtec head. They do have lower redlines, but they also ONLY came with automatics and had no oil squirters. Honda considers just one of those things to require a huge reduction in redline.
In the real world, the H23A holds power to 200-300rpm lower than the H22A but makes more horsepower in most cases. In terms of extra wear, the pistons are seeing the same amount of friction at 7200rpm with a H23 crank as an H22 pistons see at 7500.
You'd still be reliable with a 97mm crank from an F23 motor, it's really the FRM sleeves that will eventually cause it to wear out.
thx for the replies
so what your saying hiprofile is ,
i should lower the rev limiter to 7200 an ill be ok .... ?
question is would the crank hold the higher rev after fine balancing i suppose no one really knows.
mhhhh many regards so fa anyway
Not exactly. A lot of mild H22 builds make peak power at 7500rpm, so the same setup with H23 crank will peak at a slightly lower RPM. If the parts you're using usually peak at 8000rpm, the H23 crank will likely peak a bit lower.
As far as reliability, a longer stroke motor will always wear out a little faster vs a shorter stroke motor if used at the same RPM's.
alright im changing all wear and tear parts on that engine ...having a bit of trouble finding new oem pistons.
you see ill be driving the car on weekends and when there is sun all the other time it´ll be sitting in the garage. im not going to be racing it every all so often im gonna give some but thats it
i just want to do the job right and getting as much information out of every forum as possible
this comming weekend i will be disassembling my h23 for internals
and giving away crank for fine balancing
ive already removed the squirters out of the h22 and thinking about getting an elimination kit as well
have you any knowledge on that
The OEM H23A vtec motor doesn't have oil squirters either. I've seen built H22's last a few hundred miles because of human error, and I've seen motors built from (rusty) spare parts that would take a beating and ask for more. In other words the parts combination won't be an issue if it's built right.
see im trying to use as much original parts as possible except where i think aftermarket parts are more reliable ..
as for now im hoping things go well an i´ll keep you updated
do you know if i need to adjust any timing or mapping on ecu after i changed the crank
many regards
many regards
Be careful... an H22A piston attached to a H23 rod and crankshaft sticks up out of the top of the block a couple thousandths. This can lead to engine damage: valve to piston contact as well as piston to head contact is likely unless you use a thicker head gasket (which offsets any gains in compression that the H22 piston creates over the H23A piston).
as far as i´ve read from several members i should be fine !
ive read my share on this topic thats how i came to this idea
please correct me or the written knowledge of his topic
http://www.importatlanta.com/forums/...ild-beast.html
