lsv aem cam gear install
Re: lsv aem cam gear install
i understand what they are for and the use. my issue was someone told me that b16 and gsr gears have different amount of teeth and under the aem gear description they sell them for both. also was told i would never get perfect timing with lsv. this is when i said "my question is if i zero the gears and put them on should i be all set?" but this question was failed to be answered. it was a general question
gsr b16 itr all have the same teeth
and yes gears alone will give you hp if tuned on a dyno to watch results
EJ8CIVIC
07-17-2007 06:22 PM
