ls obd2 swap in eg hatch
Old 05-06-2013, 08:08 AM
eg6_ftw's Avatar
Icon3 ls obd2 swap in eg hatch
Hey guys so I'm in a pickle lol I recently swapped out the tired d15 out of my hatch and I picked up an Ls swapped everything in but it tries to start but just doesn't things I've done as of last night
Compression check
Checked for spark replaced ecu,fuses, main relay
I can't really figure it out any help guys?
Old 05-06-2013, 08:14 AM
eg6_ftw's Avatar
Default Re: ls obd2 swap in eg hatch
Also swapped the obd2 wire harness out but I'm more than possitive it works because my buddy is running a 00 gsr wire harness on his hatch runs just fine
Old 05-06-2013, 08:18 AM
nealnanoHX's Avatar
More info please. What ECU are you running?
Old 05-06-2013, 08:45 AM
eg6_ftw's Avatar
I tried two obd1 p75's and even tried my po5
Old 05-06-2013, 09:44 AM
Marvin1985's Avatar
Did you move the wire for the fuel pump?
Nvm this. This is for EKs
Old 05-06-2013, 09:49 AM
eg6_ftw's Avatar
Nope am I supposed to?
Old 05-06-2013, 11:29 AM
92lxsleeper's Avatar
all you have to do is use a obd1 ls distributor and your FACTORY harness. you will not plug in the crank position sensor on the oil pump tho.
and a obd1 ecu.
Old 05-06-2013, 11:57 AM
Marvin1985's Avatar
I looked it up. As far as EGs go all you need is the ls engine harness and plug it to the shock tower plug on your eg. Then use a obd1 ecu
Old 05-06-2013, 12:03 PM
eg6_ftw's Avatar
That's what I did went out bought an obd1 p75 and I'm using the Ls wire harness as many people have said they are comparable with the Eg strut tower plugs . Everything is plugged in just won't start
Old 05-06-2013, 12:06 PM
eg6_ftw's Avatar
http://technet.ff-squad.com/hybrid.92-95.obd2.htm
Made sure of it looked it up before I even put the swap in
Old 05-06-2013, 02:13 PM
Marvin1985's Avatar
Do you hear the pump prime?
What color spark were you getting from the plugs?
Do you have any grounds loose?
Old 05-06-2013, 03:11 PM
eg6_ftw's Avatar
Checked all grounds cleaned the mating surface fuel pump I do hear somewhat a faint prime . I got spark ,I can't really tell what color since I'm out in pure daylight and can't see what color it could be
Old 05-06-2013, 03:37 PM
well the distributor still needs to be wired to obd1 i believe. personally i would have just used the original eg harness and a obd1 distributor. (Guranteed to work that way)
Old 05-06-2013, 03:39 PM
could you could try using the obd2 computer with a obd1 - obd2 a/b conversion harness
eg6_ftw's Avatar
Well I know that as long as I can use the obd2 harness I can use the alternator and distributor .
As of 10min ago I can't hear the fuel pump prime anymore
Old 05-06-2013, 03:41 PM
eg6_ftw's Avatar
I can but wouldn't that be the same thing as using and obd1 ecu?
Old 05-06-2013, 05:15 PM
Marvin1985's Avatar
If the pump is pressurized you won't hear it. Pull the dizzy and check the prongs that meet the camshaft. There was a guy before that somehow broke the prongs and it wouldn't crank the cam.
Old 05-07-2013, 05:26 AM
nealnanoHX's Avatar
Yeah you need a OBD1 dizzy for sure.
Old 05-07-2013, 08:06 AM
eg6_ftw's Avatar
Not if I'm using the obd2 harness I've ran my old Eg like that .
Old 05-09-2013, 07:31 AM
eg6_ftw's Avatar
I havnt touched the motor I pulled it from a wrecked integra and all I did was throw a clutch flywheel and tranny on it
jthrasher1
11-19-2010 06:41 PM
leondx
04-19-2010 02:50 AM
jamelin
10-10-2009 04:53 PM
pipojdm
09-13-2008 01:09 AM
92civichatch1
10-21-2005 05:34 PM
Quick Reply: ls obd2 swap in eg hatch
