OBD1 H22 swap into eg question
I have a 95 prelude and i'm planning on swapping the motor into my eg hatch, my question is if I use the harness from the eg hatch what modifications do I need to make on the harness for it to work, I've seen that I need to lengthen altornator wires, lengthen wire for oil pressure sensor, and lengthen wires for IAT sensor, i'll probably get an internal coil dizzy to make it a little easier, just wondering if there is anything else I'm going to need to modify.
EG6-SiR
04-13-2006 03:56 AM
