'94 Del Sol S B18c5 swap questions
Hello everyone, I have a 94 Del Sol S that I am planning on swapping to a B18c5. I know I need the Del Sol VTEC shift linkage, b series mounts and the del sol vtec axles. The engine I'm buying comes with
"Complete Head
Complete Block
Intake Manifold
Exhaust Manifold
Sensors
Fuel Rail
Injectors
Distributor
Throttle Body
Alternator
Starter
Wiring Harness
Power Steering Pump
OBD2 Manual ECU
FWD Manual LSD Transmission".
What else is necessary for this swap? Will my current exhaust work with this? And what steps are necessary after instillation of the motor?(bleeding clutch, brakes, anything along those lines that I need to do) Thanks
"Complete Head
Complete Block
Intake Manifold
Exhaust Manifold
Sensors
Fuel Rail
Injectors
Distributor
Throttle Body
Alternator
Starter
Wiring Harness
Power Steering Pump
OBD2 Manual ECU
Re: '94 Del Sol S B18c5 swap questions
You'll want to replace the clutch. You'll also play hell with your wiring harness - an engine replacement is a good time to replace your wiring harness as well, but it isn't necessary.
thats it? do I need a obi conversion harness or something like that? what about a B series t bracket? I've just been reading and cant exactly find out everything I need. thanks
thanks thatll help. but now do i have all the required parts? Do I need this B series t bracket or no? I only see it listed on a few of the many forums listing the required parts for a del sol d to b series swap. thanks for all the help!
JDM CRX
08-29-2003 06:12 AM
