B18C1 into EM1 AC Question
I have an EM1 that I swapped a GSR longblock into. When I got the car, it had all AC components removed. I want to reinstall the AC into the car.
I have a line on an AC system from an EM1 that the guy removed, but is still using the AC Compressor mount in his car.
Will a P72 Bracket work for me in the EM1 chassis?
Thanks in advance.
Thanks in advance.
Re: B18C1 into EM1 AC Question
It depends was your EM1 a D series or a B series originally and is the EM1 AC you are getting form a D series or B series? Either will work but it make a difference in what AC bracket you need. If it is a D series AC compressor you need a, AC bracket from either a B20 CRV or a Del Sol Vtec. If it is a B series compressor then you can use any B18 or B16 bracket.
You do realize the EM1 is the 00 Civic Si, right?
I'm curious b/c the part numbers are different between the GSR bracket and the Si.
camoxiong
08-14-2014 01:51 PM
slowpokesi
17
07-20-2002 08:31 AM
