b18c5 on em1
hello,
Just found a b18c5 in the juck yard without an ECU.
Just wana know if the s4c transmission on my si 2000 (b16) will be fine with b18c5.
Will the ECU in the below link be perfectly fine for running b18c5 on my civic?
Any other details to take into consideration about wiring?
Thanks.
http://www.ebay.com/itm/JDM-P73-OBD2...80198789141%26
Thanks.
Tranny and everything should bolt up fine, but that ecu is obd2a you need obd2b.
Could probably run in on the stock ecu till yuo find the right one or get a tuned ecu
and jumper harness for obd1.
The intake air temp sensor is different on the c5. You'll either need to swap connectors to plug in the c5s or put your IAT in your intake arm. You could use that ecu just get an OBD2b to OBD2a adapter harness.
dwarfsinhondas
Engine Management and Tuning
Apr 7, 2008 11:47 PM
