h22 swap in eg
h22 swap in eg
ok so i picked up a 95 hatch with jdm h22a swap and i like it the car runs great pulls hard but it vibrates A LOT like in side the car everything vibrates and rattles. i know half the problem is i have stock CIVIC exhaust with stock CIVIC cat which doesnt help being restricted and ive also got stupid solid ebay mounts in it. just wondering if any other h22 eg guys could help me on what mounts to do and what i can do to subside the vibration. cause its so loud inside the car cant even have a conversation..
Re: h22 swap in eg
Has the guy took apart the dash? If he has then he might have half assed it puttin together and not put all the screws and clips in. Or check ur rear engine mount, u might need to replace it if its worn or torn seein how it is closer to the firewall and cause everything to vibrate inside
Re: h22 swap in eg
It's dc dash swapped but the dash isn't the only thing that rattles the rear quarter plastics vibrate, vibrates the windshield so the rear view mirror vibrates, everything. Everything vibrates and I hate it. I've got solid egay mounts and stock exhaust for a civic could any of that do it?
Re: h22 swap in eg
Can u feel the floor board shake too? Mayb u should check ur exhaust pipe hangers ( the rubber thing that holds the exhaust piping up, might b hittin underneath and causing rattling.
Also have u checked ur motor mounts to see if they haven't been worn or torn? My brother rear motor mount was worn out and was hittin metal causing to vibrate the inside the car and we could hear a thud whenever he shifts. Changed it out and problem fixed.
Re: h22 swap in eg
vapor5555
05-03-2009 08:52 PM
EGcivicBoy
10-31-2003 12:15 PM
