plz help?
Old Mar 4, 2013 | 05:08 PM
ericnnz23's Avatar
Default plz help?
wanting to buy a gsr b18c1 obd1 if im correct?have a 1992 honda civic eg..my piston rod shot out of my block this morning need advice what should i do??
Old Mar 4, 2013 | 05:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: plz help?
Check the hybrid forum for everything you'll need
Old Mar 4, 2013 | 05:18 PM
ericnnz23's Avatar
thanks for the advice
Old Mar 4, 2013 | 07:53 PM
ericnnz23's Avatar
How do I know if my car is obd1?
Old Mar 5, 2013 | 01:31 AM
Technical Hero
92-95 civic is obd1
Old Mar 5, 2013 | 06:21 AM
Eg.ls.turbo's Avatar
Just find a bare gsr block and do a rebuild. I got some gsr rods and pistons for sale if u need it
Old Mar 5, 2013 | 08:28 AM
kyliejohn1129's Avatar
I got a 99 JDM type r long block for sale
Old Mar 5, 2013 | 01:52 PM
ericnnz23's Avatar
How much for the pistons and rods? ?Were they in working condition when pulled out? Why you take them out? My friend has a bare block he is willing to give to me if I go that route . wouldn't I be safer buying a complete b18c1?
Old Mar 5, 2013 | 01:54 PM
ericnnz23's Avatar
How much? Bare or with pistons and rods? In working condition?
Old Mar 5, 2013 | 06:05 PM
It's a running motor it's In my car I'm about to pull it out this weekend
Old Mar 5, 2013 | 06:36 PM
Yea still in workin order pulled it out cause I went with high compression pistons. The pistons and rods plus shippin ill do $80 with shippin.
It is safer for a complete engine if ur willing to spend a couple grand.
If u rebuild it it'll be under $800 or more
Old Mar 5, 2013 | 07:22 PM
ericnnz23's Avatar
I got the money to buy a new engine but where could I buy a legit motor from, happen to know?
Old Mar 6, 2013 | 02:01 AM
Yea me lol or HMO motors $2000 for a 99 JDM type r longblock is a good deal with header and moroso pan and skunk2 manifold ported all stock besides that shipping isn't that bad either
Old Mar 6, 2013 | 06:44 AM
Hmo I like. ^^^^^ what he said sounds like a good deal mayb
Old Mar 6, 2013 | 12:13 PM
I went h2b so I am keeping my tranny and pulling the motor . It runs perfect and ill give you a type r base map chip and 3 in intake with k&n
Old Mar 7, 2013 | 05:49 PM
ericnnz23's Avatar
How much for the longblock? How do I know if it will fit in my car?
Old Mar 7, 2013 | 05:55 PM
It's the same as a gsr block just dif head all you would need is a chipped ecu like one from pherable.net there cheap and your good to go.
Call me 321-652-6496 ill explain it
Old Mar 7, 2013 | 06:43 PM
It'll fit, everything same except the type r head has a better valve train and the head flows better
Old Mar 7, 2013 | 09:13 PM
ericnnz23's Avatar
i have a 99 b16 head what block can i use?have the b16 tranny too
Old Mar 7, 2013 | 09:23 PM
U can use a gsr block or type r block to keep it simple. Unless u want to do a ls-v or b20v but its a lot more money and work. Personally I would go with a type r block with type r internals, but if ur on a budget I'd go with the gsr block. Any those two block will b a good choice for ur b16 head.
Old Mar 7, 2013 | 09:25 PM
The difference between a gsr block and type r block is the the type r internals are lighter than the gsr internals correct me if I'm wrong anybody.
Old Mar 11, 2013 | 03:25 PM
ericnnz23's Avatar
so where would be the best place to send my gsr block for a rebuild going to pick one up for 300 complete..send me a picture of your rods and pistons
Old Mar 11, 2013 | 10:54 PM
Not sure what machine shop is good over ther in Cali. Just check around and see. Ask to check the block for cracks and hone and pressure wash and u should b good to go. Make sure the the cylinders haven't been bore cause te pistons I have are stock 81mm pistons
91DA-C
Dec 16, 2010 03:00 AM
black99x
Apr 16, 2008 12:38 PM
GenIIIMrDuece
Apr 20, 2006 07:55 AM
B18C1CYA
May 22, 2005 09:05 AM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
