Adding a CKF to an OBD1 engine. Hurdles?
Old Oct 9, 2003 | 04:11 AM
Ehron's Avatar
Default Adding a CKF to an OBD1 engine. Hurdles?
Already searched to no avail. What is the difficulty of adding a CKF to an OBD1 engine?
So far it appears I need a new oil pump. What else? Any machining required?
Thanks guys.
Old Oct 9, 2003 | 11:07 AM
Katman's Avatar
Default Re: Adding a CKF to an OBD1 engine. Hurdles? (Ehron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehron &raquo;</TD></TR><TR><TD CLASS="quote">Already searched to no avail. What is the difficulty of adding a CKF to an OBD1 engine?
Thanks guys.</TD></TR></TABLE>
Well, you'll need to give more info about your engine setup....as to why you want to wire in a CKF sensor. Only US OBD2 B & D-series engines use this sensor -- is it safe to assume you're running an OBD2 engine in an OBD1 vehicle? if you are, just stick with using an OBD1 ecu and you won't have to worry about the CKF sensor at all. If not, spill some more info about your setup so others or myself can help you.
gratis..
Old Oct 10, 2003 | 11:53 AM
Ehron's Avatar
Default Re: Adding a CKF to an OBD1 engine. Hurdles? (Katman)
I was looking at picking up an OBD1 gsr block. I need to keep my OBD2 b16a2 ecu to pass emissions. See the dilemma?
Any info?
Thanks.
Old Oct 10, 2003 | 06:46 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehron &raquo;</TD></TR><TR><TD CLASS="quote">I was looking at picking up an OBD1 gsr block. I need to keep my OBD2 b16a2 ecu to pass emissions. See the dilemma?
Any info?
Thanks.</TD></TR></TABLE>
aaaahh ok..well then yes, you'll have to slap an OBD2 US B-series oil pump on the OBD1 engine in order to comply......boo..
Old Oct 10, 2003 | 06:52 PM
Ehron's Avatar
So all I would have to replace is the oil pump? That sounds easy enough. Then no machining/switching of pressed in parts is required.
Thanks for the help Katman.
Old Oct 10, 2003 | 06:55 PM
bossman032's Avatar
engine can be same year or newer.
so I think its safe to usa that motor with OBD1 ECU, Harness, Dizzy.
Old Oct 11, 2003 | 06:21 AM
Race Egr's Avatar
you need a obd2 oil pump and you will also need the ckf sensor are you gonna be running a obd2 head
Old Oct 11, 2003 | 03:39 PM
cinq's Avatar
Default Re: Adding a CKF to an OBD1 engine. Hurdles? (ek-guru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-guru &raquo;</TD></TR><TR><TD CLASS="quote">you need a obd2 oil pump and you will also need the ckf sensor are you gonna be running a obd2 head</TD></TR></TABLE>
That above and OBD2 Distributor. Dont bother asking the dealer for the ckf sensor. Will cost you an arm for that. $250+ just for the sensor. Better off buying from someone online. Oh...might need OBD2 vtec ecu too.
Old Oct 11, 2003 | 06:17 PM
Ehron's Avatar
Thanks for the info guys. Seems like I could have been clearer about what I currently have. I already have an OBD2 engine (2000 b16a2), ecu, and everything associated it. I was looking at picking up a 95 gsr block to bolt to my b16a2 head and tranny. I planned on reusing the sensor I already have.
I have to keep the OBD2 ecu to pass emissions. That is why I was asking the question. Once again, thanks for all the input.
Old Oct 12, 2003 | 07:36 PM
Race Egr's Avatar
are you doing a poor man's type r or are you gonna build up the motor because if you build up the motor I would use a obd1 ecu much better for tuning
mariog96teg
Dec 12, 2013 10:03 PM
B18 CYA
May 8, 2004 01:32 PM
torq2k
Oct 28, 2003 10:28 AM
Ehron
Oct 15, 2003 08:14 AM
airon
Jun 12, 2001 03:09 PM
