b16a head on b18c block wiring?
If i but a b16a head on a b18c block what wiring will i need to make it run cuz i have a full b18c1 motor but the head is kinda busted up. Can i use the wiring from the b18c or do i need to get new ecu, wiring, and everything?
Re: b16a head on b18c block wiring? (envious1320)
all you have to do is extend the wires that go to the sensor on the back of the manifold.. (you know you cant use your GSR manifold I assume.)
you will also need the upper radiator hose from the B16 or ITR
tommyblaze
11-29-2003 07:28 AM
