b20-vtec valve spring and retainer?
Should the valve spring and retainer be replace if you were to go with a B16a head? If so, which one would you recommend? Thanks
Re: b20-vtec valve spring and retainer?
It is only necessary to change valve springs and retainers if you are changing camshafts... if you intend to use the stock B16A cams, you wouldn't need to change a thing.
sik civic
16
08-17-2005 05:58 PM
