h22 in 92 cx hatch,,, will JRSC fit?
Old 10-11-2003, 12:48 AM
SofaKing's Avatar
Default h22 in 92 cx hatch,,, will JRSC fit?
I did some research,, never found anything to support what i was looking for...
some people said youll need to fabricate the shock tower to make room for the pulleys and stuff. ANYone have any pics of this setup? do they exist?
yeah yeah i could turbo it,, but i have my GSR for that h22 SC'ed in a hatch will haul ***, and yet retain the sleeper look
----let me know if it can be done and how much of a pain in the *** it is! i will be using HCP mounts, DSS stage III axles, quiafe LSD. This car will rip!
-jimbo
Old 10-11-2003, 08:10 AM
SofaKing's Avatar
Default Re: h22 in 92 cx hatch,,, will JRSC fit? (SofaKing)
werd?
Old 10-11-2003, 08:29 AM
dragnize's Avatar
i dont think i've seen a sc h22 hatch before..... try it and find out. let us know how it goes
Old 10-11-2003, 02:51 PM
hondaeg5's Avatar
Default Re: h22 in 92 cx hatch,,, will JRSC fit? (dragnize)
dont know if it will work. i did a search and really didnt find anything either. i would assume no because of the placement of the motor. try it and let us know
Old 10-11-2003, 07:30 PM
hybrid93SIvic's Avatar
Default Re: h22 in 92 cx hatch,,, will JRSC fit? (hondaeg5)
turbo it instead
Old 10-11-2003, 07:36 PM
Downey's Avatar
i know that in an EG hatch that the intake manifold sits about 1" away from the prop valve. its a tight fit. if the JRSC sits further back in the prelude that the stock manifold then i doubt it will fit.
im sure if you really want it to fit.. you could move a few things or even cut the firewall a bit.
a JRSC H22A would be sick..
Old 10-11-2003, 10:49 PM
Pikachu's Avatar
I think it will kick *** actually but it'll probably be on the expensive side. Hypothetically, you can put it in but you will have to cut out some of the firewall and since it's such a tight fit, you will definately need to drop the motor out first, install it, stick it back in. If you do this, the setup would be one of a kind since I haven't heard anyone pull this one off. Good Luck with the setup.
Old 10-12-2003, 07:58 AM
redrum eg6's Avatar
you can do anything if you really want, it just depends how much work and money you want it to involve.
ive never seen a sc'ed h22 hatch, but if anyone finds one or does it id love to see it
Old 10-12-2003, 08:36 AM
SofaKing's Avatar
Default Re: (redrum eg6)
well, when i sell my single turbo 93 Rx7,,, that takes care of the money issues,,, as for the time issues... i live in Ill Annoy (illinios) so i have the next 6 months of **** weather to work on the project in the garage.
Anyone have pics of the JRSC on a h22 in a Prelude?? this way i can get a basic feel as to where all the belts and hardware are mounted on it. Also to see if it gets closer to the firewall and all that good stuff.
This is basically gonna be a weekend/drag car, so i dont care too much if i butch the firewall up a ton,,, hey, less weight!
Old 10-12-2003, 12:00 PM
hondaeg5's Avatar
Default Re: (SofaKing)
bump. i wanna see this to!
Old 10-12-2003, 08:19 PM
eg:R's Avatar
fire wall will have to be cut, and relocate break lines
Old 10-12-2003, 09:12 PM
Pikachu's Avatar
It would definately be a sight to see. I'd rather go turbo though since there's plenty of room for it...
Old 10-13-2003, 01:43 AM
miyo's Avatar
Default Re: (Pikachu)
Ask Newman. I think he mentioned in a past post about someone who did this.
Old 10-13-2003, 04:56 AM
SleeprCivic's Avatar
Default Re: (miyo)
Ya, I asked about this before, but I believe that you probably need to cut some of the driver side shock tower to clear either a pulley or a belt...
Old 10-13-2003, 02:28 PM
SofaKing's Avatar
Default Re: (SleeprCivic)
Just managed to find some pics of 96-up ludes with the JRSC,,, tight *** fit by the firewall,,, i think i could manage the pulley side. Seems like it may be a really tight fit in the EG chassis... but then again,,, i do have all winter
Old 10-13-2003, 04:28 PM
fastwanabe's Avatar
I've been tossing the idea of running this type of supercharger. I sure I could make a bracket where the A/C compressor would sit and try to stuff this thing in there.
Old 10-14-2003, 07:33 AM
dc2h22's Avatar
Default Re: (fastwanabe)
The shock tower for sure has to be modified to get it to work!
Old 10-14-2003, 09:17 AM
hondaZvic's Avatar
Default Re: (dc2h22)
that would be nice if vortech made a sc for the H22. or do they already?
Old 10-14-2003, 09:20 AM
RTFM
v4lu3s's Avatar
on mine the shock tower and firewall/prop valve are so close that reworking of the sheet metal would hahve to be done. in teh case of teh shockt tower i dont know whata you could do since i would be very concerned about the structural integrity of it after cutting a big piece of it out of the way.
Old 10-14-2003, 10:22 AM
SofaKing's Avatar
Default Re: (v4lu3s)
What i would cut out, i will make a peice out of metal,, except it will be indented or pushed back to allow room. Ill weld it in just to have the structural suport. also a good upper strut bar will help.
--So far my biggest concern is the firewall clearance,, i wont be too enthused to reroute the brake distribution block. Then a gain 6 months is a long time...
Old 10-14-2003, 10:58 AM
jarel's Avatar
I think the s/c will be sitting very very close to the firewall. I have a pic somewhere on my comp of a jrsc h22 in a civic hatch, and it looked clean. I also think that Doc Charles did one of these before and ran with no problems. But not 100% on that.
Old 10-14-2003, 11:14 AM
SofaKing's Avatar
Default Re: (chyknees)
dood... If you could find pics and post,, or at least me able to send me one. that would be excellent. The car would be a mad sleeper/smote car with this setup.
BTW do JRSC's have a fairly long life to them>? i do a lot of driving, granted this wont be my daily driver, but the track i go to is 100miles away. Miles add up quick!
Old 10-14-2003, 01:51 PM
PUSHER's Avatar
If you daily drive the jrsc 10psi+ it will eat the blades up if you dont have any form of cooling. As for how long they last under normal 8psi use I'm not sure.
Old 10-14-2003, 02:25 PM
SofaKing's Avatar
Default Re: (PUSHER)
lame,, turbo kit is looking like the answer more and more every day...
Old 10-14-2003, 02:29 PM
PUSHER's Avatar
bah, do the sc.... you got 6 months to do it.... just make sure you daily drive everywhere on slicks so you can atleast have some traction=P
Quick Reply: h22 in 92 cx hatch,,, will JRSC fit?
