can anyone help, 5 lug rear trailing arms?...........
just picked up a 5 lug assembly for my integra from a salvage yard. car was hit in the rear left and the suspension pieces were unsalvageable. so i have 3 corners and need the rear left.
does anyone know if the either the prelude rear trailing arms/crv's are compatable? or if the hub from an itr can be placed onto the civic trailing arm assembly?
Re: can anyone help, 5 lug rear trailing arms?........... (bgod)
I recently went through the same thing myself. The ITR hub will not fit the civic or GS/LS/GSR integra rear disc brake spindle because the ITR spindle is longer. I could not find annother trailing arm (or spindle) that would work, and I work in a Honda/Acura only junkyard. I ended up buying a new trailing arm from the dealer and I discovered that Acura lists three different part numbers for the trailing arms (depending on the year) and that the 2001 arm is the least expensive. I did not see any difference between the new (2001) arm and the used (1997) arm.
Toy Civic
07-11-2010 03:56 PM
