'94 USDM Del Sol B16 Into '96 CX Hatch --- Help
Well, like the post says, I need help with this swap. I've searched and gone through many posts over the last hour and a half. Can't really get much info on swapping this engine into '96+ civic.
-I know I need the rear mount from a 99-00 si for sure but what about the rest of the mounts? Can the del sol mounts be used or the cx?
-Secondly, it looks like the del sol engine wiring harness can't be used and the stock cx should be used. Can a different harness be used that makes the swap easier?
-If the cx harnes is used what kind of rewiring is involved?
-Would the purchase of an ODB-II ECM make things easier? If so, which ECM?
-Can the del sol shift linkage be used?
-Anything else I missed?
Thanks in advance
Tom
Thanks in advance
Tom
Re: '94 USDM Del Sol B16 Into '96 CX Hatch --- Help (diycx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diycx »</TD></TR><TR><TD CLASS="quote">-I know I need the rear mount from a 99-00 si for sure but what about the rest of the mounts? Can the del sol mounts be used or the cx?</TD></TR></TABLE>
You'll need the 99-00 Si rear mount, lower front tranny mount and driver's side mount bracket. Reuse your stock upper tranny mount. Del Sol VTEC A/C bracket if you want to keep A/C.
This and answers to all of your other questions can be found if you search on here. Just search for any EK swap info. and I'm sure you'll find everything you need.
Cru Jones
25
04-14-2003 06:56 PM
