Crank Swaps
Old Oct 2, 2003 | 12:23 PM
10secwantabe's Avatar
Default Crank Swaps
Between the 1.6, 1.8, 2.0 and the 2.2 liter. Are there any interchangable crankshafts. I'm thrying to develope a short stroke (Stroker) engine for my sons H/B.
Thank you in advance,
Jake
Old Oct 2, 2003 | 12:47 PM
irev210's Avatar
Default Re: Crank Swaps (10secwantabe)
sure b16 b18c1 b18c5 b17 b18a/b and b20b/z cranks are all internchangeable
b18a/b are the same as b20b/z
Old Oct 2, 2003 | 01:03 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10secwantabe &raquo;</TD></TR><TR><TD CLASS="quote">Between the 1.6, 1.8, 2.0 and the 2.2 liter. Are there any interchangable crankshafts. I'm thrying to develope a short stroke (Stroker) engine for my sons H/B.
Jake </TD></TR></TABLE>
yep, theyre mostly all interchangeable just remember honda motors like to make power up high in the rpm range, and changing the r/s ratio of a motor (for the worse) wont help your cause...
Old Oct 5, 2003 | 11:04 PM
turtle-eg's Avatar
Default Re: Crank Swaps (LsVtec92Hatch)
If the cranks are interchangable, wouldn't it work out good to swap a ls or gsr crank, pistons, rods, into a cheap B16 block to get 1.8l?
Old Oct 6, 2003 | 06:32 AM
irev210's Avatar
Default Re: Crank Swaps (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">If the cranks are interchangable, wouldn't it work out good to swap a ls or gsr crank, pistons, rods, into a cheap B16 block to get 1.8l? </TD></TR></TABLE>
the deck height of b18/b20/b16b is higher then a b16
the piston would come out of the block if u put a b18 crank and b18 rods in a b16 block. However, you can get custom rods and make the whole concept work, just alot of hassle.
most common is taking LS crank and putting in gsr block.
cltitus
Feb 12, 2007 07:45 AM
AllMoToRB18c
13
Jun 27, 2006 01:58 PM
HamiltonRex
Dec 21, 2005 12:42 AM
ridexstraight
Dec 29, 2004 10:16 PM
pomansouth01
Apr 22, 2004 10:43 AM
