Problem with the IAC
Old Oct 9, 2003 | 03:43 PM
-Bionic-'s Avatar
Former Sponsor
Default Problem with the IAC
I'm almost done with my H22 accord swap. The main problem that I have is that the IAC is not working.
I'm using the F23 harness, and the accord IAC plug has three wires, while the H22 plug has two. Out of the three, I choose the wire that had the best continuity, and the one that had battery voltage. Now, I don't know which is the ground and power on the H22 IAC sensor, so I tried to switch them around. In both cases, I would hear a clicking noise, but once I started the engine I still had problems with the IAC.
What should I do next?
Thanks
Old Oct 9, 2003 | 04:36 PM
poison's Avatar
Default Re: Problem with the IAC (-Bionic-)
What wire colors are on your three wire IACV plug?
If there is an ORG wire, leave that out of the picture and wire up the other two.
hondamyheart
Aug 24, 2018 02:12 PM
sleepyH22
Oct 7, 2007 05:22 PM
jakeiscool
Sep 27, 2007 02:15 PM
-Bionic-
Oct 10, 2003 12:11 PM
buck02
Aug 31, 2003 05:42 AM
