which distributor? b20z motor w/ pr4 ECU
swap= 98 dx chassis, dx wiring harness, 2001 b20z motor, and dx distributor internals with LS cap.
My swap was "finished" 4 months ago but i still can't get the car to run like it should with anything but the DX sohc ECU. With the DX ecu it runs a little lean but great otherwise. When I use the PR4 obd1 ecu, the car is extrememly slow above 3.5k RPM. I think it may be the fact that my distributor has the internals from a 98 sohc dx.
I read all related topics after searching distributor and found nothing....anyone have advice??
Re: which distributor? b20z motor w/ pr4 ECU (moike)
You can use any 94-01 Integra nonVTEC or a 97-01 CRV distributor. If you want complete plug and play compatibility, stick with the 96-99 Integra LS,RS,GS or 97-99 CRV.
