WTF broken hasport mount?????
What do you guys make of this? The mount was fine when the motor was put in a week ago, the car has been driven gingerly per break in process. Pop the hood and find this:
Will hasport warranty this?
Re: WTF broken hasport mount????? (MrSmith)
i've seen this happen before. i thought hasport had alll the mounts fixed, guess not. but anyways, they did warranty my friends mounts, with no problems.
Re: WTF broken hasport mount????? (CRX Spaz)
Sorry for the missunderstanding. The mounts were used before with the B17 that was in the car. We pulled the B17 and dropped in a B18 longblock using the same mounts. That was a week ago. Then the above happened as I said during the break in process. This is redrum's car (above) not mine just to clarify.
Thanks for the quick response brian, I was hoping you would chime in
you probably have your motor installed kinda crooked..if all the mounts were tightend down and you forced the motor in then that will put extra stress on one of the mounts..most likely it wasnt installed as good as it could have been
SoullessJapaneseMachine
16
12-24-2020 07:11 PM
Brewer
03-23-2004 07:30 PM
