h22 problems
Old Sep 29, 2003 | 10:26 PM
lcaruca97's Avatar
Default smart people look here..
ok heres my problems...
car runs sluggish when timing is set correctly and the knock sensor cel comes on after about 45 seconds. So i have it advanced pretty far, as a result, the car idles at about 2300-2500 rpm. AND when i am driving, if I stop the car and then start it again it will run horrible. Very bad hesitation when at part throttle and the idle drops to about 1200-1500 rpms, but if i turn the car off and back on again quickly it will start working good again. Very weird. any help would be great.
_______
Modified by lcaruca97 at 11:02 AM 10/1/2003
Old Sep 30, 2003 | 01:02 PM
Lyrikz's Avatar
Default Re: h22 problems (lcaruca97)
What year car? motor? ecu? need more info.. alot more..
Old Sep 30, 2003 | 03:26 PM
lcaruca97's Avatar
Default Re: h22 problems (Lyrikz)
uhmmm well the thread is titled "h22" help and my sig says 94 jdm h22 and 97 acura cl. with mods listed.
Old Sep 30, 2003 | 07:53 PM
lcaruca97's Avatar
B-ump
Old Oct 1, 2003 | 08:03 AM
lcaruca97's Avatar
Old Oct 1, 2003 | 08:20 AM
Turbogixxer's Avatar
Vacuum leak? Did you do a timing belt on the motor? Check your grounds too
Old Oct 1, 2003 | 10:39 AM
poison's Avatar
Sounds to me like the MAP sensor isn't getting the right vacuum, faulty/dirty IACV, or incorrect TPS setting.
Old Oct 1, 2003 | 11:24 AM
fastwanabe's Avatar
Default Re: h22 problems (poison)
also make sure everything is grounded correctly.
Old Oct 1, 2003 | 04:44 PM
lcaruca97's Avatar
Default Re: h22 problems (fastwanabe)
well. i do hear a hiss commin from the intake manifold area but i cannot pinpoint it. And i have replaced all the gaskets on the manifold. Cant figure out where its commin from. Anyways... how i can chck for a leak? Oh, and the car threw a timing belt when I was outta town last week so its brand new. I dunno. Getting very fustruated. btw all the grounds are in good order. but ill recheck em anyway.
Modified by lcaruca97 at 8:04 PM 10/1/2003
Old Oct 1, 2003 | 05:02 PM
poison's Avatar
I would recommend capping off every nipple on there (the ones mainly going to the IAB box underneath the intake manifold).
could be possible you have a leak in that black box.
also put your hand on the throttle body and see if the motor dies at all.
Old Oct 1, 2003 | 05:05 PM
lcaruca97's Avatar
like you mean cover the intake hole comepletely? also i dont think i am totally clear on where the iab is.
Old Oct 2, 2003 | 08:39 PM
lcaruca97's Avatar
Old Oct 2, 2003 | 10:33 PM
d_mina's Avatar
newbie question here for poison ...but what you said about the throttle body...IT IS supposed to turn off if you cover the throttle body rite because then that would mean that there is a leak? please clarify this for me
Old Oct 3, 2003 | 05:07 AM
Jason kiDD's Avatar
If the car threw a timing belt then it is a possibility that you have bent vavles. I would do a compression test to be sure, but that is what I would think first..
Sorry to say though...
Old Oct 3, 2003 | 05:48 PM
lcaruca97's Avatar
Default Re: h22 problems (Jason kiDD)
btw it had these same problems before the belt broke.. i had the engine checked out when it happened. Everything was a ok... thank god!
92Lude94
Mar 31, 2010 03:51 PM
lcaruca97
Sep 3, 2004 07:44 AM
