H22 Tranny Hoses/Lines?? Where do they go??
Okay.. so I have my H22 in my Integra finally up and running. Only problem is that 5th gear grinds sometimes. Im about to check my tranny fluid level and add some more in there.
One thing that I didnt hook up was the two hoses that were on the tranny. The hoses were already cut when I got motor from HMO. When I take off the hoses.. its just two fittings that stick out on the back/top part of the tranny. Seems like maybe coolant lines?? Does anyone know where youre supposed to hook this up to? Since I have a hybrid swap I dont have any of those lines running on the chassis. Should I just leave it? or 'T' it into a coolant hose? If so, which line??
I hope I'm not screwing anything up by driving it like this. Any replys would be greatly appreciated!! Thanks!
Re: H22 Tranny Hoses/Lines?? Where do they go?? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Nope, those are not required. You can loop them off.
What mount kit did you use? HCP?</TD></TR></TABLE>
Thanks for the quick reply. You are the H22 Hybrid master
Yeah, I used HCP. Im going to borrow my friends digi and take pics soon... hopefully.
Re: H22 Tranny Hoses/Lines?? Where do they go?? (ozzyman)
read this if your trans is grinding.
https://honda-tech.com/zerothread?id=641177
Hmm, sounds like you didn't trim off the tranny mount enough.
Definitely take some pictures.
Infact, try putting it in 5th gear and even Reverse, and see what the clearance is with the tranny mount and the cable assembly on the transmission.
Re: (BlackJDMdeath)
Cool thanks guys. I think I'm going to try that GM Syncromesh tranny fluid. The shifter assembly on the tranny clears just fine. I noticed that when I drive it and push the clutch in ALL the way to put it in 5th gear it doesnt grind.
And yeah, Ill just loop the tranny lines with a hose.
Honda-Tech people are the best, thanks for the reply guys.
Kp_VtekNiks
10-13-2003 01:25 PM
