which axles for a cable LS tranny in EG?
Re: which axles for a cable LS tranny in EG?
slow ***... aren't you runnin a b16a? if so the get rid of that tranny!!! it will kill you. but if you aren't then 94+ integra as mentioned before.
Re: which axles for a cable LS tranny in EG? (advanracing62)
yeah I'm running a b16, but I want the LS tranny for the turbo setup....will it even work better? I still have my old 94 gsr tranny in my garage still....which one would you use with a turbo setup?
New User
Re: which axles for a cable LS tranny in EG? (Aj.)
Keep the Ls trans for a turbo it has a higher gear ratio if you use the gsr you won't have a much of a 1st gear. If you use a cable trans you need 90 -93 axles in your trans.
Jason
Jason
blackcrx16
05-17-2007 08:23 PM
JDM*addiction
05-09-2007 11:05 AM
schtozo
02-21-2003 11:48 AM
