does this sound like a good setup?
Old May 27, 2001 | 08:24 AM
tsjag17's Avatar
New User
Default does this sound like a good setup?
spoon pistons and mugen head gasket.. 11.6 compression
jdm type r headers
comptech exhaust
skunk cams
obd1 ecu and harness
act clutch
aem pulleys
aem cam gears
b&m fpr
what do u think that setup would do in a 2000 gs-r?
Old May 27, 2001 | 03:09 PM
92Si's Avatar
New User
Default Re: does this sound like a good setup? (tsjag17)
1. If you are going to take the entire block apart, why not get some better Rods & ARP rod bolts. http://www.theoldone.com for Pistons... "If endyn makes it and you bought something else, you made the first mistake..."
2. AEM cam gears only have 3 bolts, don't let your baby get f'd up from slippage, get some better gears.
3. Chip that ECU, locash, Skunk2... P28's are reasonable.
Otherwise soudns good, good luck, have fun.
Old May 27, 2001 | 03:59 PM
92Si's Avatar
New User
Damn double post, don't hit refresh after you post something I guess!! This BB is awesome, although I like the functionality of mine a bit better (www.3rdshift.org), few bugs...
[Modified by 92Si, 1:00 AM 5/28/2001]
Old May 29, 2001 | 01:20 AM
IM ALL BOB's Avatar
Default Re: does this sound like a good setup? (92Si)
just to ask.. this is for a b18c engine.. well no need for the spoon pistons.. dropping JDM ITR pistons into a B18C1 will raise the CR to 11.3:1 or so
and the thinner head gasket will raise the CR to 11.6:1 EASILY ,always remember to make sure that your engine will not detonate with the high CR of 11.6:1 .. and I'm certain you'll be running 92 or better octane damn gas prices
LuckyJDM
Aug 22, 2014 11:36 PM
Thepanda
Jun 23, 2007 08:19 AM
Cspeclude
Feb 5, 2003 12:01 PM
JeffNA
Feb 27, 2002 08:05 AM
teg92
Oct 15, 2001 11:58 AM
