swap question? please help
Old Jun 6, 2001 | 09:10 AM
gargamel's Avatar
New User
Default swap question? please help
I just dropped a b18b in my 95 civic coupe. what do about the gap between the header and the civic catalytic converter. weld an exstension or does an integra cat fit? any suggestion will help
Old Jun 6, 2001 | 09:28 AM
advanracing62's Avatar
Default Re: swap question? please help (gargamel)
use the teg cat or weld an extension it's up to you... i would use the teg cat
Old Jun 6, 2001 | 09:59 AM
eg6ajk's Avatar
or you can just get a b16a or ITR header complete.....or just the down pipe off a ITR (USDM only)
Old Jun 6, 2001 | 10:06 AM
Default Re: swap question? please help (eg6ajk)
isn't the B16 header too short for the B18 block??? just tried it on a gsr and it touched the oil pan.
Old Jun 6, 2001 | 01:27 PM
cheezemaster's Avatar
New User
Default Re: swap question? please help (advanracing62)
i just used the b16 downpipe which will bolt right up to the civic cat. plus, its got the o2 bung in the perfect spot.
Old Jun 6, 2001 | 01:46 PM
Yellow Dragon's Avatar
test pipe.
Old Jun 6, 2001 | 05:25 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: swap question? please help (Yellow Dragon)
Use the 94-95 Teg cat.
jeremy_dane
Feb 27, 2009 10:31 AM
DM95eg
16
Jun 21, 2005 08:32 AM
eg1.8r
Feb 28, 2005 09:27 PM
94lshatchback
10
Feb 26, 2005 10:17 AM
TRENDSETTLER
Oct 6, 2002 06:33 PM
