Swap question??? Please answer ASAP (searched but could not find)
I have a 93 DX Hatch (canadian), I'm looking at getting a B18C from a 99 GSR.
What ECU and wiring harness will it probably have OBD1 or OBD2?
Is the install any harder for the OBD2 then OBD1? Any other problems I may need to know about before purchasing?
Thanks Greatly!!
Thanks Greatly!!
Re: Swap question??? Please answer ASAP (93GAhatch)
From a 99 gsr it'll have OBD2 ECU, as well as OBD2 harness and motor.
I would obtain an OBD1 P72 from a 94-95 Integra GSR.
You will have to convert the motor and obtain an OBD1 engine harness to use the 99 GSR swap.
This includes converting the fuel injector harness plugs, as well as the dist.
HTH.
HTH.
