is there a place that tells me what everything on the motor is?
Im still in the progress on the gsr in my 92 hatch. it has been good for about a year. But i kinda want to mess with everything now. Its a obd-2 motor and im using an obd-1 computer, so there are things on the motor that i don't need. and there are some vacume things i want to mess with too. and im jsut wondering if there is anywhere i can go that tells me what everything on the motor is.
I know there is a green plug next to the vtec on the gsr, what is that?
and what is the sensor on top the intake(right in the middle of the intake, not map sensor or tps sensor) And there is a black canister on the fire wall, what is that? and there is a black box on the fire wall just behind the intake, what is that?
Re: is there a place that tells me what everything on the motor is? (92hatchy)
I just want to trace all the wires from my ecu to the engine to see if everything is right. and i want to find out what sensors on the obd-2 motor i don't need casue im running an obd-1 ecu. (i already got rid of one of the o2 sensors)
but i just don't know what everything on the motor is. so following the wire for the evap purge control selenoid and not knowing what it is is stupid.
http://www.helminc.com best thing you can buy for working on your car.
Coopa B18c5
06-06-2013 06:19 PM
