what clutch and flywheel to use with YS1 cble and 97 b18c1
also what flywheel would I need
do I just get the B18 clutch and flywheel, or do I need to get a clutch and flywheel that will fit the cable tranny
thanks
thanks
Re: what clutch and flywheel to use with YS1 cble and 97 b18c1 (DOHCarp)
YS1 cable trans is a big-shaft tranny, so you need any 92+ Integra clutch (same between the hydro and the cable YS1 tranny). 90-91 Integra transmissions (A1, S1, Y1, J1) are all small shaft transmissions and use a different clutch.
All B-series flywheels are the same size so any will work.
Re: what clutch and flywheel to use with YS1 cble and 97 b18c1 (Muckman)
Im putting a '95 B18C1 into a '91 Integra LS. Wont the clutch from the 91 Gen2 work too?
Re: what clutch and flywheel to use with YS1 cble and 97 b18c1 (Newman)
I have a 91 CRX DX with a 96 B18B1 and 92 YS1 cable GSR tranny. I'm using a 94 GSR flywheel and a Exedy clutch kit for a 92 Integra GSR.
so any b series 92+ integra clutch will work
thanks for the help
thanks for the help
Basicly, they give u the same pressureplate and clutch disc as any hydro tranny, but they give u the proper throwout bearing.
Hope this helps.
So everything will be fine if I swap over my YS1 tranny, clutch and flywheel from my '91 Gen2 and it will fit and work with the '95 B18C1?
If you have a YS1 cable transmission, then YES the clutch disc, pressure plate, and flywheel will all work on your 95 B18C1, assuming you have a Y80 or S80 transmission on there. But then if you have a 91 Integra, there was no YS1 transmission for those years... the YS1 cable transmission were only found in 92-93 Integras.
impreziv
07-20-2008 10:53 AM
