ecu ?
Old Feb 26, 2003 | 06:14 PM
4drb18ek's Avatar
Default ecu ?
just got a 99 b18c1 swap for my 1996 civic dx 4dr but it came from a 1992 civic with a obd1 ecu can i use any obd2 ecu or is thier a certin ecu i have to get? and do i have to change the wire harness also?
Old Feb 26, 2003 | 06:18 PM
jg's Avatar
jg
Default Re: ecu ? (delete187)
I'm selling this harness(below) to use a obd2 ecu in obd1 car. What ecu did you have plugged in your car. You said you have a '96 civic(obd2?) - so what's came from a '92 civic?
here's the jumper i'm selling...$165 shipped
Jeff - jgale00@hotmail.com
Old Feb 26, 2003 | 06:41 PM
4drb18ek's Avatar
Default Re: ecu ? (jg)
the motor is not in yet, im asking that i need a OBD2 ecu for my car because the motor came with an OBD1 ecu. and also asking if i have to change the wire harness also?
Old Feb 26, 2003 | 06:43 PM
4drb18ek's Avatar
can i get any OBD2 ecu or is their a certin ecu that i need for my motor??
Old Feb 26, 2003 | 06:44 PM
4drb18ek's Avatar
and if i have to change the harness or not?
Old Mar 1, 2003 | 07:13 AM
4drb18ek's Avatar
any one?
Old Mar 1, 2003 | 07:42 AM
jg's Avatar
jg
If your car is obd1, you can use the obd1 gsr ecu. Should plug right in. If your car is obd2, use the a obd2 gsr ecu, or get a obd2-1 jumper to use it. If your car is obd1, and the motor is obd2, you can use a obd1-2 jumper(pictured above) to use a obd2 ecu in your obd1 car. I hope that wasn't too confusing.
I'm no expert on this- so somebody tell me if i'm wrong!!!
Joeski99Si
Sep 4, 2008 10:18 AM
killacam661
21
Aug 7, 2007 07:45 AM
eater_eg6
Dec 12, 2005 12:54 AM
4drb18ek
Feb 26, 2003 06:59 PM
43MA
Oct 30, 2002 04:58 AM
