B18C1 Code 45
Old Mar 2, 2003 | 04:57 PM
BlVlW313's Avatar
Default B18C1 Code 45
well i found out that i was throwing code 45 the other day.
code 45: to rich/lean
what can i do to go about fixing this.
i changed my secondary o2 cause the car shop says it wasnt reading correctly.
oh and my idle is also really weird idles a lil low. and car will shake. but not too bad.
i need to get this fixed soon. so any help would be appreiciated.
Old Mar 3, 2003 | 08:02 AM
1fastminivan's Avatar
Default Re: B18C1 Code 45 (BlVlW313)
anyone?
Old Mar 3, 2003 | 05:20 PM
VTECVillain's Avatar
Check your ignition timing.
Old Mar 4, 2003 | 04:02 AM
TurboBumblBee's Avatar
what mods do you have?? if u got an adjustable fuel pressure regulator it will do that.. i know cause i just fixed my boys cause his said he was too rich cause his meter was at like 40 psi idle and it needs to be 30psi stock and like 38 WOT
Old Mar 8, 2003 | 10:40 AM
BlVlW313's Avatar
Default Re: B18C1 Code 45 (Hybrid95CivicEX)
well the problem is fixed.
i got my vavles adjusted at carboy(houston shop, dont ever go there they just want your money they dont care how they do service)
well the check enigne light came on the day after they ajdusted my valves. but i didnt think anything of it.
apparently i took it to this other shop and they re did the valves and everything is aiight. so i thought id update this thread for people who also have this prob. thanx for all the help.
xlusiveracer
Honda CR-V & Element
Jan 6, 2017 05:54 AM
97CWITR
Mar 13, 2015 12:53 PM
crx_si-r
47
Feb 22, 2010 06:39 PM
95hatchfire
Jan 12, 2005 10:52 AM
ITR #1202
May 10, 2003 11:34 AM
